In some cases, when we define a widening method, the widened segment is drawn with "line", not "spiral".
Also, sometimes the length of the lines are not appropriate, since they are too long.
Is there a way that the user could control the entity type to use in widening or to control the maximum length of line entities?
Solved by mathewkol. Go to Solution.
