Hello all,
I have a new desktop that I am now using with Civil 3d, but I am lacking the Xsect2Surf tool, and the link from the fellas that created is bad. Does anybody have the original *.exe file to install on my desktop?
Garrett
Solved by Jeff_M. Go to Solution.
Solved by neilyj666. Go to Solution.
This should do it - rename to a .zip
Thank you for sending.
I am getting an error that will not allow Civil 3d to load it. Basically, I am installing per the Readme, but I am getting errors as below:
Command: NETLOAD
Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Xsect2Surf2014.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
File name: 'file:///C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Xsect2Surf2014.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
at loadmgd()
I Jeff,
It's been a while since you posted it, but is there a version of that XSECT2SURF planned for 2016 ?
Hopefully I've got the right @wes.newman so assuming I have is there any chance of updating the code so it runs in 2016?
Attached is the error that appears when attempting to run the 2015 dll after NETLOADing.
Many thanks
I just got a new machine and need to install Visual Studio.
I'll get an updated version posted this week.
Wes
Here is a version compiled on 2016.
Looks like there was a change in 2015 SP2 to the ResolveEventHandler which is causing the load issue.
The attached dll has resolved the serilazation problem.
-Wes
Jennifer,
The 2015 version no longer works due to a change in the API in one of the Service Packs.
I've made the needed adjustments and recompiled on 2016, which is the one posted earlier in the thread.
Apologies as I don't have 2015 installed to update that version of the tool.
-Wes
Just downloaded and extracted the 2016 version, I did a NETLOAD of the extension, but when I type in the command xsect2surf, nothing shows up
I'm on 2016 SP2 what could be causing the issue for it not to load?
Hey Autodesk,
come on: why don't you put it on the product (power tools?)?
Sometime we have to do incredible things because of the missing model, and this kind of tools are really handy
Come on
Hi!
I'm so sorry to piggyback on this question, but do you have the original installer for this tool? I've tried to get it, but the link has been taken down from the original site. This tool looks so incredibly helpful!
Thanks so much!!!
Do you know if this will work on 2017? I'm getting an Unknown Command message after i load the dll
Hi
I have C3D 2018.How can i use this tool on C3D 2018?
Thank you
