Solved by jrauch. Go to Solution.
Solved by rkmcswain. Go to Solution.
I don't understand what the problem is. You can assign truecolors to the components of a surface style.
Good morning,
Thanks for your reply!
I've created a screencast which shows the problem. I hope it is clear to you know.
This is a bit obscure, but there's a tool in the Germany country kit that may help you. If you have access to country kits, download Germany and find the tool in the Toolspace Toolbox. Hope this helps!
The tools that @rkmcswain and @jrauch mentioned are useful, and there are others a bit more robust (more analysis types are supported) available, RedTrabsitConsultants has one in the app store, the Sincpac-C3D add-on has them included. however, if you are ok with the colors but just need them to be TrueColor instead of ACI, as the Analyses all create, then the new tool added to the Sincpac may be of interest. It was just added, today, at the request of a customer, so it's not available for use just yet, but will be soon.
