As i mentioned in the subject is the a way to get an arrow with Ascend grade differ than descend grade from profile on the alignment label.
To clarify that i need the Ascend grade to have an arrow with the increasing of station on alignment and the descend grade have an arrow has a direction on opposite to the increasing of alignment station.
This is how I did it:
I made a profile geomtry point label style the addes GradeIn and GradeOut to the pvi's (i'm sure it could be adjusted to accomodate a VC)
In the style I created and two headed arrow using a line component a oothe _solidFill arrow block. So composing it looked like this <--------->
Arrow1 for negative grade and Arrow2 for positive grade, were the block names
I made two expressions
IF({Grade In}<=0,.1/12,0.00001) (for negative grade)
IF({Grade In}>=0,.1/12,0.00001) (for positive grade)
assign these to the block height in the composer and the appropriate arrow shows based on grade
Joe Bouza
Jon Thank you for your support i got the expression
@onsionsi1 which are you using?
@jjfuller & @onsionsi1 i am pleased with the label style and the expressions placing the label midway between PVI's , but all goes kablooee when I add a VC, as far as the placement goes.
I added an expression for the x offset of the label to be halfway between PVI's , but it appears c3d does not recognize the pvi when a vc is added, although the codestyle does.
how are you placing the grade label on the alignments? I attached my drawing for reference
Joe Bouza
Joe - Downloaded your drawing and I verified the issue. I removed the label from the label group and when I added it back only slected the PVI and profile end station as geometry points to label - and it worked fine. Nice job on the solution! Why that would make a differnce is beyond me, but I guess C3D uses the labels instead of the geometry to determine the next geometry point.
Like always there is never a blanket solution. The x offset strategy falls apart when horizontal curves are thrown into the mix, which is frusting because we are so close to nailing this down! Because roadways generally have vertical curves I wonder if it would be better to place the labels at the BVC and EVC stations as opposed to the PVI. Then no x offset would be necessary. I guess it really depends on what the scenario is. - Just brainstorming here.
If anyone is interested I created the arrow using the AECCArrow (because it includes the line and arrow head) and used the expression
IF({Grade In}>=0,0,DEG2RAD(180)) to set the angle in the label style. Not that its any better but it does cut down on the number of elements.
Your Dwg attached for reference.
@Joe-Bouza wrote:This is how I did it:
Hi Joseph
I'm trying to do exactly you mentioned, and it isn't working for me. The arrow direction isn't right.
Could you help me, please?
I'm using your dwg file to understand how to do that, and isn't working as well.
BTW I'd like to fix the label for low and high point at the profile and isn't working properly.
File attached
Thanks in advance
Fabricio
Hi guys,
I've fixed the arrow direction problem!!
Now it is working fantastic!!
I just need to fix the label for high and low point at the profile.
I think is better create a new post about it.
Fabricio
Hola my friend
Could you please tell me how you fixed the arrow fixed the arrow direction problem?
thanks in advance!
