Hi All,
Could you please assist me, my 'toes' are intersecting and i need to create one clean smooth model, i am using multiple site with one surface, any ideas pleas....
Place them all in one site and the toes should merge in the order you created them.
Same site and object interact.
Different site means they do not iinnteract.
John Mayo
I am not a big fan of gradings due to reliabilty.
Backup copy and save your file often.
In general I try to grade out and up from the bottom of a design.
With the pipe networks, go to the ribbon's home tab, click the chevron arrow on the Create Design panel to expose the hidden commands. Click the Set Pipe Network Catalog and make sure it is pointing to the correct path and that you catalog exists at that path. By default the path is,
C:\ProgramData\Autodesk\C3D <version>\enu\Pipes Catalog
DEfault paths may change due to Windows and acad versions.
John Mayo
Hello, it worked perfectly, thank you so much.
I have another question if you dont mind please... I am busy designing a roundhead for a causeway and i’m not sure what steps to take as it is multi platformed with slopes, can you please assist me... (scan attached)
Also, my pipe network catalogue is empty and i need to place a pipe under my causeway, I’m using C3D 2017, any ideas please? (screenshot attached)
Thank you so much for your assistance, it is much appreciated.
Thank you John, much appreciated, let me give it a go and I will get back to you to let you know how it goes... thank you
Hi John, sorry to bug, if i'm Grading from the bottom up, how do i fill the 'gaps' for the 4.5m, 5m and 3m flat parts please?
