This one in driving me nuts.
In the office I've started in, we have a template with special line types. In some drawing they show correctly in others they don't. In a drawing they did show correctly, i saved it for later use, now it doesn't...
A good example of this is the attached screenshot. Both are from the same file. you can see the drawing2.dwg screen has a lot of the special linetypes showing only as a continuous line type while the other window (_Autocad***-ACG.dwt) show the linetypes correctly. Here is the crux. The dwg file was created off the dwt file.
any ideas?
I have attached the two files as mentioned.
Solved by Neilw_05. Go to Solution.
Solved by BushW. Go to Solution.
Joe Bouza
Hello @Anonymous
Unfortunately, when I opened the files, I got One or more SHX files are missing. But, I found this solved post that might offer a solution since you are using custom linetypes. Hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit.
Since some of the linetypes are scaling properly in both files, I would first check to be sure all the lines have a linetypescale=1 in their properties. The LTSCALE, PSLTSCALE, MSLTSCALE variables would affect all lines, not just certain ones. The other potential problem would be differences in the shapes being used by the 2 drawings.
Thanks Joseph,
yes all those values are =1.
Id agree these might be complex line types, but I don't how they are created. I did try to run the lisp routine that creates a .lin file from a dwg but it failed to run (not sure why).
I have changed all the .shx text styles to height = 0, closed and reopened cad no joy.
Still not understanding why a dwg created from a template looses the line types definition.
BTW ACAD C3D 2016
Aaron
I'm no expert on shapes but I do know the shapes are stored in each user's font folder by default. Thus 2 users may see different behavior depending on which versions of the shape files they have in their support folders.
The 3 missing shape files contain custom shapes used in the line types as mentioned by @BushW.
These files must be included in the Support FIles Search Path in Options.
Command: OPTIONS > Files tab > Support File Search Path > Add
(This should likely be setup within your organization if they are linetypes that get used frequently, you may want to ask).
As an example here's what I see in both drawings for "Drainage" lines:
Here are the missing shape files causing the warning & continuous line display:
LINETYPE [FENCELINE1] uses SHAPE # [134] in the file [ANZ.shx]
LINETYPE [ARRBACK] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [ARRBACK-hidden] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [ARRTO] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [ARRTO- hidden] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [BATTING] uses SHAPE # [136] in the file [ANZ.shx]
LINETYPE [BLDLEFT] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [BLDRIGHT] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [FENCELINE2] uses SHAPE # [133] in the file [ANZ.shx]
LINETYPE [TOPLEFT] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [TOPRIGHT] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [TRACKS] uses SHAPE # [130] in the file [ANZ.shx]
LINETYPE [YLEFT] uses SHAPE # [132] in the file [ANZ.shx]
LINETYPE [ZIGZAG] uses SHAPE # [131] in the file [ANZ.shx]
LINETYPE [FENCELINE4] uses SHAPE # [37] in the file [INFRA.shx]
LINETYPE [CDCJ] uses SHAPE # [56] in the file [INFRA.shx]
LINETYPE [CONCRETE_LINED_CHANNEL] uses SHAPE # [40] in the file [INFRA.shx]
LINETYPE [DCJ] uses SHAPE # [57] in the file [INFRA.shx]
LINETYPE [DRAIN_SWALE_LINED] uses SHAPE # [6] in the file [INFRA.shx]
LINETYPE [DRAIN_SWALE_UNLINED] uses SHAPE # [6] in the file [INFRA.shx]
LINETYPE [DRAIN_TABLE_LINED] uses SHAPE # [22] in the file [INFRA.shx]
LINETYPE [DRAIN_TABLE_UNLINED] uses SHAPE # [22] in the file [INFRA.shx]
LINETYPE [EX_BUILDING_LHS] uses SHAPE # [37] in the file [INFRA.shx]
LINETYPE [IJ] uses SHAPE # [64] in the file [INFRA.shx]
LINETYPE [EX_ROAD_EDGE_LHS] uses SHAPE # [67] in the file [SKM_INFRA.shx]
The following SHAPE FILE is loaded: [ltypeshp.shx]
The following SHAPE FILE is loaded: [ANZ.shx]
The following SHAPE FILE is loaded: [SKM_INFRA.shx]
The following SHAPE FILE is loaded: [INFRA.shx]
Hope that helps.
Thanks Wendell,
I jumped onto another machine in the office and copied the whole fonts folder over to mine. And it works!!
Very excited.
Still confused how the template views correctly but that's autoCAD i guess.
Using the FNDSHP.LSP by @rkmcswain .
Also Check the physical line type scale per object is 1. if the were set to something other it could make ya nuts
Joe Bouza
If you place the custom linetype out on a network drive. Then add the network location to the Support File Search Path.
Then when you update the linetypes everyone in the office will get hem.
I have similar problem and tried everything on here or at least I think I tried everything but my fenceline1 type is still not showing properly in my drawing. Here is what I got...I opened my base drawing which is like my templet drawing and draw pline with fenceline1 style. at first it shows a continues line but after I do LTSCALE...MsLTSCALE etc. and regen it shows properly in my Base drawing then I copy the line I drew and past it in my problem drawing and that messes everything up. By that I mean is not showing properly again.I'm working on my laptop from home so I don't have to the server all my files are on OneDrive. Please help
You don't have the same shape files in one drawing as the other. You probably need to reimport the linetypes in the other drawing.
Where do you see and compare that? I'm Sorry still a nub. And can I and how copy shape files from one drawing to another ? Thanks
Type "shape" and then "?".
usually shapes are brought in when you load linetypes but depends if you have custom linetypes. Then you will need the "shapename.shx" of your custom files. Look into the lineytpes and see how they work. Shapes can't be loaded into drawings unless you compile them from a shape file.
