This is not really related to a highway project but a architectural project I am working on. I have a dwt that I have downloaded from the web and a dwg file which I have received from my friend.
Basically the drawing template which is a arch d imperial dwt file 24"x36" and a dwg file is drawn to a 1:1 scale.
I want to try to place the dwg file into the template file and make the dwg inside the dwt file using a architectural scale to fit within the dwt.
I will need to edit my dwt file but this can be done later.
Is it ok to post my questions here?
Joe Bouza
If you are trying to use an architectural drawing within a C3D drawing it may be like pushing a rope up a stream. Many conflicts.
Bill
@Joe-Bouza wrote:
Sure you can.
Dwt is just a drawing file with a special extension. Anything you can do in a dwg can be done in a dwt.
INSERT. Your file set the x and y scale to 12 ( assuming imperial ) and explode. Then ....
Wait a minute you want to maintain the integrity of the dwt. Star a file new from the big A , browse to the arch dwt, then insert and explode and go to work
Hi Joe Bouza,
I'll give that a try..
The problem I am having now is that I currently have a floor plan drawing which is a scale of 1:1 in feet. As you can see the arrows for
the dimensions are way to big. I went to the web and say that you can do a annotative scale which will make all the text, dimension, arrow all at the scale of 1:1
I have been trying to do this in autocad civil 3d 2012 for a couple of days but it never makes any changes. I was wondering if you have some time can you fix this for me?
Joe Bouza
