Good Day
The attached file depicts two cases of a channel in a fill condition. Using the available daylight or cut/fill subassembly options results in a fill sloping down from top-of-channel to the surface in both cases, however I want the fill to slope upward in the first case and downward in the second, as shown in the images. I would ideally want to define this behaviour with Subassembly Composer but I have not figured out a way of achieving this. Please could I solicit the assistance of my learned fellow forum members?
All assistance is greatly appreciated.
Kindly
Ntuthuko
Solved by Dexterel. Go to Solution.
I'll preface this with the fact I have not tried it.
what happens if you put a negative slope in, instead of positive (or the other way around)?
Thinking about it logically, you may have to use the parameter editor to modify it after the fact. I'm not 100% positive how C3D determines a cut vs a fill section (certain distance out from the start point?)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Hi Dexterel
yes, I have become reasonably familiar with Subassembly Composer, however please tell me how exactly to express that condition for the decision?
Ntuthuko
Download from url https://ufile.io/c58c1 PKT file
First decision check to have solution to slope upwards.
Second decision checks that the upwards slope length will be smaller than 10 (pick a reasonable length, you don't want a 1000 length slope).
Just out of interest. Do you know how I can identify the top-of-bank in order to set the fill to extend to it regardless of the slope (provided the slope and distance are within certain limits, of course)?
I'm thinking the solution would entail somehow extracting from the surface a polyline that traces the top-of-bank and then targeting it?
Ntuthuko
My Apologies. I've been unable to sign in for a while now. Thank you for going through the trouble of assisting me. Much appreciated.
Ntuthuko
Hi, I am struck with the same problem, can I get the PKT as it is showing as its been removed
Comment deleted. I misread.
Christopher Stevens
