Civil 3D Forum
Forcing a Fill to Slope Upward From Corridor
13 REPLIES 13
Message 1 of 14
Ntuthuko.
1384 Views, 13 Replies
Good Day
The attached file depicts two cases of a channel in a fill condition. Using the available daylight or cut/fill subassembly options results in a fill sloping down from top-of-channel to the surface in both cases, however I want the fill to slope upward in the first case and downward in the second, as shown in the images. I would ideally want to define this behaviour with Subassembly Composer but I have not figured out a way of achieving this. Please could I solicit the assistance of my learned fellow forum members?
All assistance is greatly appreciated.
Kindly
Ntuthuko
13 REPLIES 13
Message 2 of 14
I'll preface this with the fact I have not tried it.
what happens if you put a negative slope in, instead of positive (or the other way around)?
Thinking about it logically, you may have to use the parameter editor to modify it after the fact.  I'm not 100% positive how C3D determines a cut vs a fill section (certain distance out from the start point?)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 3 of 14
Dexterel
in reply to: chriscowgill7373
Do you know Subassembly composer?
You can add a decision like this:
If you have solution to slope upwards and slope length is smaller than something, slope else -slope. Got it? If not I will can make a pkt file to show you.
Message 4 of 14
Ntuthuko.
in reply to: Dexterel
Hi Dexterel
yes, I have become reasonably familiar with Subassembly Composer, however please tell me how exactly to express that condition for the decision?
Ntuthuko
Message 5 of 14
Dexterel
in reply to: Ntuthuko.
Download from url https://ufile.io/c58c1 PKT file
First decision check to have solution to slope upwards.
Second decision checks that the upwards slope length will be smaller than 10 (pick a reasonable length, you don't want a 1000 length slope).
Message 6 of 14
Ntuthuko.
That works perfectly. Thank you very much Dexterel. Your assistance is highly appreciated.
Ntuthuko
Message 7 of 14
Ntuthuko.
Just out of interest. Do you know how I can identify the top-of-bank in order to set the fill to extend to it regardless of the slope (provided the slope and distance are within certain limits, of course)?
I'm thinking the solution would entail somehow extracting from the surface a polyline that traces the top-of-bank and then targeting it?
Ntuthuko
Message 8 of 14
Ntuthuko.
Sorry, I will post the above question as a separate thread.
Thank you.
Message 9 of 14
Dexterel
You need to have a polyline for the top of bank. Its ridicules hard to make a subassembly that finds top of bank.
You can add an extra decision in the beginning: target_offset.isvalid
- false make slope as before (slope to surface)
- true make slope offset on surface
If its not clear I will make a PKT
Message 10 of 14
Ntuthuko.
Yes please illustrate with a PKT if you don't mind. That will be helpful.
Thank you.
Ntuthuko
Message 11 of 14
Dexterel
Message 12 of 14
Ntuthuko.
My Apologies. I've been unable to sign in for a while now. Thank you for going through the trouble of assisting me. Much appreciated.
Ntuthuko
Message 13 of 14
Sriram.S.Dali
Hi, I am struck with the same problem, can I get the PKT as it is showing as its been removed
Message 14 of 14
ChrisRS
in reply to: Sriram.S.Dali
Comment deleted. I misread.
Christopher Stevens
Rail Community
