A client works in Civil 3D 2017 off their local server and, per project:
The data shortcuts work fine for an indefinite period of time when it suddenly stops working, forcing them to re-associate the project to multiple drawings.
The default behaviour of the “broken” files is to accept the last used data shortcuts folder as the working folder. After they are re-associated the project to multiple drawings they perform normally again.
What is causing the data shortcuts association to fail? Is it a Civil 3D issue or might the cause be server maintenance tasks (indexing, for example)? Does anyone experienced similar issues or have any advice on the matter?
