Show only
Search instead for
I want to make band cut and band fill but with this expression profile 1 minus profile 2 minus 53 cm that means I want the difference not to design I want the difference between ngl and subbase
You can create a copy of the lower profile and reduce it by 53cm. Then you can use this new surface for bands. Or else you can lower the bottom surface by 53cm and use it for bands. Thanks
I have in one dwg 61 roads and design of them every time change and many of engineers work on it so I want it as an expression not to lower or up or copy
