Civil 3D Forum
Curve Calculator - Degree of Curvature
20 REPLIES 20
Message 1 of 21
dschofield1
2767 Views, 20 Replies
Related to Civil 3D 2013.  I'm trying to use the curve calculator to obtain values of a curve.  The problem is the value for Degree of Curvature is 00d00'00" everytime.  Is this broken in 2013 or is there some ambient setting I need to set? I've attached a screen shot.
Many Thanks,
Tags (1)
20 REPLIES 20
Message 2 of 21
Jeff_M
in reply to: dschofield1
Have you installed the Service Pack? I have, and it appears to work correctly for me. Although the readme does not say this was an item that was corrected.
Message 3 of 21
dgordon
I get the same result with the curve calculator and I do not have the service pack installed.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 4 of 21
dgordon
in reply to: dgordon
I tried this on my 2011 version with all service packs installed and the curve calculator worked normally.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 5 of 21
dschofield1
I have SP 1 installed but still get 0 for Degree of Curvature.
Message 6 of 21
klugb
Ditto,
2013 SP1 and "0" for degree of curve here.
Jeff,
Can you post your test drawing to make sure it's not a drawing thing. I did try with my template AND the NCS standard though.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 7 of 21
Jeff_M
in reply to: klugb
Bruce, I used the stock NCS dwt to test with.
Message 8 of 21
Jeff_M
in reply to: klugb
Here's a setting to check, since I just noticed the OP's unit arc length is 0
Message 9 of 21
klugb
in reply to: Jeff_M
The mystery continues!
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 10 of 21
Jeff_M
in reply to: klugb
OK, so looks like there is a bug when selecting the curve. If you input the values to calc a curve, without first selecting a curve, the DoC works correctly. As soon as you select an arc in the drawing, the unit arc length gets set to 0.
Message 11 of 21
dschofield1
in reply to: Jeff_M
Jeff, That's exactly what I'm seeing also.
Message 12 of 21
in reply to: Jeff_M
I'm running version 2012 with the service pack installed and it works fine when I click on an arc. Not the OP's arc but one I drew.
Message 13 of 21
dschofield1
dsigman, thanks for the input.  It seems to be limited to 2013 and something to do with a bug in the unit arc length.
Message 14 of 21
Jeff_M
Correct, works fine in 2012 for me as well. This issue is limited to the 2013 product.
Message 15 of 21
SurveyorLee
I have the same issue in 2011, with the service packs installed.  To make it work, change the "Fixed .." from Delta to Radius. Then input the info you want and see if it doesn't work.  Aggravating, but it works.
Surveyor Lee
Message 16 of 21
JamaL9722060
in reply to: Jeff_M
Hi Jeff,
Could you please elaborate a bit more how to get the dialogue box that you are showing in the screenshot (curve calculator)?
Jamal
Jamal Numan
Message 17 of 21
klugb
in reply to: JamaL9722060
From the "home" tab, under the "draw" panel last on on the list.
See Image.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 18 of 21
JamaL9722060
in reply to: klugb
Many thanks Bruce. I got it
Best
Jamal
Jamal Numan
Message 19 of 21
klugb
No Problem,
Thanks for the kudos.
Bruce Klug, P.E.
Engineer III
Design Section
Clark County Public Works
Phone: 360-397-6118 x4835
Fax: 360-759-6910
This e-mail and related attachments and any response may be subject to public disclosure under state law.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 20 of 21
dannyCXQDR
Is it possible to modify the units precision for the Curve Calculator? Changing the settings under"Units" has no effect nor does changing the settings in the Survey Database.
DD
Rail Community
