Greetings, please help me with respect to the creation of an access, I would like you to explain step by step the use of the intersection command, for the creation of it.
Greetings and many thanks, attach the file cad
The intersection wizard is very straightforward to use;
From your file it looks like your next step is to create the alignment for the access you require and then its vertical profile that ties into your main road
Making a intersection is no easy task. I don't think is realistically possible to explain everything on a forum.
Some tips: You have some problems on your surface. Add top (or bottom) overhang correction to your surfaces. See attached image.
