Hi there,
I have no idea why holes occur or how to prevent it but I thought I'd just let you know that your tip on adding points then deleting them to fix the holes was great! Sorry I couldn't be more help but but you definitely helped me save some time.
Cheers
@gnewland wrote:
I have a roadway corridor and a surface created from that corridor. After I rebuild the corridor I rebuild the surface. Whenever I rebuild the surface I get holes in it. Please look at the attached jpeg. Right now I go to the holes, add a point, then delete the point and the surface is then correct. Why does this happen and how can I fix the problem. Thanks.
think you made some edits on this surface.
Make sure you are creating this surface just from corridor definition, see attached image
