We've been using 2016 for a few weeks and the issues we are having regarding the command lag time are extreme. The lag time seems to be worse in sheet files versus base files. After picking an item, there is at least a 5-10 second delay before the software moves on - sometimes more and sometimes a complete freeze.
I've tried all the suggestions I could find and nothing seems to help. In fact, some just resulted in AutoCAD crashing and me wanting to take a hammer to my computer. Getting anything done has become painful!
Any suggestions? Is Autodesk working on this???? Thanks!
Solved by Hackett1980. Go to Solution.
2014 is pretty solid. We've recently upgraded to 2015. One tip for future reference - most people don't upgrade until Service Pack 1 for that version has been released. We usually just stay a year behind. That way, many of the bugs have been addressed in the service pack or people have found work arounds.
Kirk - this is another issue but I hope you know the answer - plan production does not copy the pipe network labels to the destination drawing. I've recreated the sheets and still nothing. The labels are in the design file profile. I even picked the labels in the source profile as well as checking the option to 'copy' - please see attachment. I've checked styles and settings in the destination drawing and all seems fine. This has never worked for us - even in 2014. Do you know of a solution? Or maybe it's just not part of the software???
Thanks for all your help! Claudia
PS: I've looked through others posts on this and haven't found a solution. I did put out a new post for this topic today and can update it if there is a solution. Thanks!
I know that it doesn't work. I'm not sure if it is by design or not. I'm pretty sure that the intent is that everything is labeled in the sheets.
Our workflow is such that we have a label style that we use for design that we use in the design plan that shows the design-relevant information only and another that we use in the production plans to help the contractor understand what he's supposed to do. The fact that the labels don't bleed through is the behavior that we want. The labels will show if you XREF the design in to the sheets (back to the original problem).
I'm sure it's not the answer you were looking for - sorry.
Back to the lag issure. I've tested with xrefs and they are the culprit as far as I can tell. Has anyone found any solution to this issue? Is there anyway of contacting autodesk directly to solve this kind of stuff?
There may not be an immediate solution.
You can use your Subscription and/or reseller to file a support request. Provide clear, precise instructions on how to duplicate the problem so the techs can test it on their end. The quicker they can duplicate the problem the sooner they can figure out how easy any fix will be.
Or simply determine that - 'Yes, there is a problem but we don't know what to do about it other that document it and close the case.'
Contact your reseller and let them take care of the BS with Autodesk. I have been doing this for quite a while now, and have only had a support case successfully resolved one time. Dan Philbrick actually called me to discuss the problem and emailed me a patch afterward. I'm pretty sure that they quickly squelched that level of customer service shortly thereafter because that was the first and last time. Now I would say that it is a waste of time to submit the support requests. The optimist in me still does it, but don't expect any results.
I think I may have found the solution. When you xref a dwg all the layers within that dwg show up in the layer dialogue box. If you have a layer filter selected which shows all layers autocad must scan all the layers everytime there is a command or selection etc...If you create a filter or select a filter that does not show all the active and xref layers then the program seems to function a lot better. Please try this approach and see what happends.
https://forums.autodesk.com/t5/autocad-forum/autocad-2016-pauses-when-selecting-objects/td-p/5615628
refer to the above link, i have been posting fixes to these lag problems I have been encountering
my posts are on the second page
Do you have the Civil 3D Performance Degradation Hotfix installed? See below...
new updates and temporary fixes to this problem are in this forum
