Civil 3D 2017 is not backward compatable.
I suspect that this is the cost of progress, so it OK. Just be aware.
When 2016 was backward compatible with 2015, AutoDesk clearly said so. It would be nice if they spoke as clearly now.
From the help File:
This topic describes the behavior when an AutoCAD Civil 3D 2017 drawing is opened in prior versions of AutoCAD Civil 3D.
Objects in a drawing saved in AutoCAD Civil 3D 2017 are available only as proxies when the drawing is opened in a prior version of the software.
Within AutoCAD Civil 3D 2017, set the PROXYGRAPHICS drawing setting to 1 to save the graphics with the drawing, otherwise a bounding box is displayed where the object is located when the drawing is opened in a prior version of the software.
Notice whenyou open an older version file:
Christopher Stevens
Solved by dsimeone. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
That probably kills my idea of snagging the 2017 pressure pipe catalog to use in 2016 then. We just made the move to 2016, don't see us moving again for a bit.
Shawn,
"That probably kills my idea of snagging the 2017 pressure pipe catalog to use in 2016 then."
I don't know if the 2017 catalogs can be used in 2016. Let me know if you try them. The 2017 Help file referes to the new catalogs but not mention if there has been any change that would prevent them from being used with 2016.
You might want to look a Project Kameleon in Atuodesk Labs. I recently added the ability to work with pressure pipe content. (I have downloaded and looked at but not worked with it.)
Christopher Stevens
@ChrisRS wrote:
Shawn,
I thought Kameleon was dead. I tried it out and asked for help and no one on the forums nor from Autodesk ever responded so I gave up. Their own tutorials wouldn't work due to changes to the software and no one from Autodesk would assist.
Few topics i'll try to respond to...
Dave Simeone
Senior Product Manager - AutoCAD Civil 3D
Thanks for the update, Dave. It's appreciated.
Thanks for the update. It is great to see Autodesk responding.
Christopher Stevens
@dsimeone, does this mean the EXPORTTOAUTOCAD drawding that is created will not be compatible with earlier versions as well. This is what i'm seeing:
https://knowledge.autodesk.com/community/screencast/7bac8fc2-3859-4214-a874-1a36f872298c
Rick Jackson
Survey CAD Technician VI
@rl_jackson, that's what you would think. But take a look at the video link that I provided and you'll see that it does not work. I've tried it on several computers and several users.
Rick Jackson
Yes, but the export should have converted those proxy objects down. Am I correct? It's always worked that way in the past.
Rick Jackson
Agreed. C3D 2017 > 2016
--is just like---
C3D 2012 > 2011 (or 2013>2012, or 2011>2010, etc)
Correct?
I'm not looking for it to convert Civil 3D objects to earlier versions. I'm simply looking for it to convert the entire drawing to AutoCAD linework with no proxy objects. I want that alignment to convert to a polyline with text labels, I want the surface to convert to bunch of polylines with elevations, etc., etc.
I believe the best solution may be to. . .
I would agree with that, and if proxyobjects = 1 in v2017, then there won't be any proxy boxes to get rid of.
And if your final desired result really is a polyline and text, you don't need to import the landxml file.
Just saw this thread.
If the ability to saveas to lower versions without exploding the aec objects caused problems, this "autocad is same version but c3d objects are not" is going to be *fun*.
The question at hand is:
If we EXPORTTOAUTOCAD, and tell the aec objects to explode, do they?
We do not care about converting c3d data back, that went out the window long ago.
The answer MUST be that , yes, the objects explode.
Just be sure to tell the batch converter or export commands to do so.
Be sure to turn off the bind in options as well as in the civil batch converter dialog, they both must be off or you get in a bind...pun semi-intended.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
@rkmcswain, at this point yes the final desire was to get it to Vanilla AutoCAD format. This was to get to a client who doesn't have Civil 3D, but only AutoCAD.
I went back through my process and I clarified it. Here's what you need to do to get it out to AutoCAD and Civil 3D:
Now if you need to get it back to AutoCAD format for someone else to use. . .because of the fact that you lost those proxy objects in step 4, you'll need to proceed to the end of step 5 and then you'll need to have it open in the earlier version of Civil 3D and then export the file to AutoCAD.
