Can anyone with a clean OOTB installation verify if the command shows up as described in this post:
My installation at work does not have it, and I need to confirm before a meeting whether or not I need to get annoyed with IT.
Thanks all!
Solved by MarySeufert. Go to Solution.
You didn't mention your version. This is a fairly new tool, introduced in Civil 3D 2016 or so.
If it's not on your menu, try typing ExportSurfacetoSolid.
Meeting happened and I brought up that all of our ribbon contents are not there. The explanation with my editorializing...They were lazy and utilized probably a 2013 deployment package... So ribbon contents are missing, but as you suggested, the command works.
Version is in Subject line
