Hi everyone,
I am working on pond project.We prepared detail part of the project with our team by using autocad. The first parts can be done in short time by using civil 3 d. (aligment, surface, corridor, volume calculation)
However it takes much time to draw detailed parts. Such as drawing of steel and its area calculation. We use major commands such as copy/paste/array/mirror .. Its takes about 5-6 day .to complate project.
When I searching on the web, I see autocad macro and I inspered by this video:
https://www.youtube.com/watch?v=7FicvnUKFOM
He give only dimension of drawing and autocad gives all drawing by using macro in minute. Maybe we spend 1 week for this parts. So, is there any macro about bridge, pond or river project. If there is, how I can access. Also I wonder how I can prepare macro about this projects. Thanks for help.
Solved by tcorey. Go to Solution.
@Alas_1234 wrote:
Hi everyone,
....Also I wonder how I can prepare macro about this projects. Thanks for help.
You can prepare you own macros using one of several programming languages that are supported by AutoCAD, including AutoLISP/VisualLISP, VBA, VB.NET, C#.NET.
Hi @Alas_1234
Please add a post with how you decide to proceed and your results so, other Community members may benefit.
Thank you for doing so.
Hi @Alas_1234
I have unmarked my post as not the solution to your question but, I assumed meant to select @tcorey post as the solution.
If the response did not work as an answer, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
No action is required if my response did work as an answer. However, I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns!
