Thanks again Autodesk for messing up my install. I installed the service pack and now my graphics are messed up again...
I have the latest video driver, I have turned Hardware Acceleration on and off, amongst other things as well. This happened with AutoCAD 2017 SP1. I uninstalled the SP1 and everything worked fine again. Now with the C3D SP1.1, it's back. It even prints these anomalies. Oh and you can't uninstall SP1.1. This is great!! NOT!!
Solved by ToddRogers-WPM. Go to Solution.
Solved by Jeff_M. Go to Solution.
@Buzz12345, Bingo! Uninstalling AcadSP1 did then allow the image to display correctly. Adding back the C3D2017 SP1.1 did not break that display and all is well here.
@ToddRogers-WPM, I found THIS thread in the Acad forum which seems to go along with Michael's findings.
Still weird how the SP affects those graphics. And why could I open the file in Irfanview when Todd couldn't?
I don't have AutoCAD SP 1 installed so that may be why I didn't have any problem with the file.
Allen Jessup
CAD Manager - Designer
Like Allen, I can open & view this thing just fine on my laptop.
Core i7 3.0GHz
12 mb ram
GeForce 940M
Now does everyone have infraworks installed? Again, like Allen I do...Could this or another adesk app be replacing a common file that enable this or is is hardware...
If you don't have infraworks try installing it just for the fun of it all. 😮
John Mayo
Well you know I have InfraWorks installed. Just double checked to see if SP1 reinstalled itself and it's not there. However, I have AutoCAD Hotfix 1,2, and 3. So, I uninstalled Hotfix 3, still there. Uninstalled Hotfix 2, still there. Uninstalled Hotfix 1, still there. THEN, I uninstalled AutoCAD 2016 SP1, and bingo! It's gone.
Well you know I have InfraWorks installed. Just double checked to see if AutoCAD 2017 SP1 reinstalled itself and it's not there. However, I have AutoCAD Hotfix 1,2, and 3. So, I uninstalled Hotfix 3, still there. Uninstalled Hotfix 2, still there. Uninstalled Hotfix 1, still there. THEN, I uninstalled AutoCAD 2016 SP1, and bingo! It's gone.
Since I never installed IDSP 2016 that fits with my results. Still very weird. Can you open it in Irfanview now?
Allen Jessup
Turns out I do have that one installed.
It looks like I must have installed every plugin available when I installed Irfanview the last time. I didn't know you could list the plugins that are installed I checked this morning.
Allen Jessup
I just installed all the plugins and works like a charm. Thanks Allen!
In case anyone is experiencing this issue.
Autodesk is asking for information from those who are not seeing SP1.1 in the Application Manager. See post #25 of this thread
Allen Jessup
Hi, the screen pixelating issue is solved by this hotfix....
Or this hotfix if you are using FDO to import your ecw files.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
I replaced the dll file (even though it was the same version as the one I already had installed) and it fixed the problem.
Many thanks.
