TinSurface have AddLine function with two parameters - vertex1 and vertex2 as TinSurfaceVertex.
How can I create a new TinSurfaceVertex for using AddLine function?
Two new points not always will create a line (triangle edge).
I will check AddStructureLine function... it seems it what I need.
Yes, that's why I said it MAY create the line. You can check if the line was created by usseing the FindEdgeAtXY and passing the midpoint between the 2 vertices you add. If it does not find an edge, add the line.
AddStructureLine? I am not seeing that in the API docs....
