When creating a Surface Direction Analysis in C3D and specify the number of ranges, it fills in the min/max directions. I am not seeing these properties available in the TinSurface or GridSurface objects. What would be used to get these values? I'm not even exactly sure what the Direction is in relation to, as the few surfaces I've applied this Analysis to did not look quite as I had expected based on the description in the help.
Is this available on TinSurface.Analysis.GetDirectionData() array of results? It includes max and min.
Hope I understood your question, let me know if that is not the case...
Got it, but I don't see that either.
Only the TinSurface.GetTerrainProperties() with Slope min/mean/max
