I discovered the "/nologo" startup switch today and love it with one exception: It is causing the font in (only) my Properties Palette to be messed up. There doesn't seem to be any error in functionality, but it's messing with my eyes and sanity. See Below:
The Target is exactly as follows:
"C:\Program Files\Autodesk\AutoCAD 2017\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2017\\AecBase.dbx" /p "custom profile" /product "C3D" /language "en-US" /nologo
I applied the switch to 3 of my launch icons and had the same result with each on. I removed the switch and relaunched with the icon and the font issue was fixed. Then I put the switch back in the target path and the issue returned.
I sure enjoy the faster load and not looking at the Splash Screen for all 30 second of a session, but staring at this properties palette for 8 hours a day isn't going to cut it.
Thanks in advance.
I have the Launch Icon Shortcut on my desktop and the same "user" pinned to my taskbar. I can edit the Target in the Launch Icon Shortcut without affecting the pinned application icon. This allows me to open the same profile in two sessions, one with the switch, and one without. I've don't that and take a screen shot of the good and the bad side by side. The Layer name in the toolbar screenshot tells which is good and which is bad.
Again, I have only noticed this anomaly it in the Properties Palette and only with the switch. The variance is most clear when comparing the
"LINETYPE SCALE" and "THICKNESS" values between pallets.
