Hello, I'm not very good at .net yet but I have a little .net program that runs a modeless dialog box that stays open while I work. The program works but its kind of annoying because I have to double click to activate my autocad window upon picking a button on my dialog box. Is there a way to make it a single click event? Here an example of one of my buttons. Thanks
Private Sub endpnt2_Click(sender As System.Object, e As System.EventArgs) Handles endpnt2.Click
A modeless dialog is running on a separate thread, not on the same as AutoCAD. That's why it says open while you work on AutoCAD.
From your button, you can get AutoCAD running instance and active it, but that will depend on how your app works. For instance, are you using Interop assemblies?
Hi Augusto,
Thanks for your reply. I'm not really sure what you mean by interop assembly. I'm pretty new to this vb.net stuff.
Can you share the references you are using on your project?
