I´m reading this:
http://blog.civil3dreminders.com/2010/03/set-elevation-points-on-feature-line.html
and in the end it says: "If I remember correctly you need to make sure the point is on the feature line before setting the point elevation."
However, "GetPointElevation" method doesn´t exist.
I´m using:
double[] points = (double[])oFtrLn.GetPoints(AeccLandFeatureLinePointType.aeccLandFeatureLinePointPI);
but it is only for vertex, point elevation are excluded of that method.
I need location of all point elevations that belong a selected feature line.
Can I erase also a point elevation?
Thank you.
Solved by Jeff_M. Go to Solution.
ok.
And for get Elevation Points?
for (int i = 0; i <= oFtrLn.ElevationPointsCount -1; i++) { ...... }
What´s the differece between Point and PI?
I understand PI and Elevation Point but I don´t know what is "Point".
About this:
I can calculate Azimut and Distance between two vertex .Then, if point have the same Azimut(Direction) and (distance<distanceBetweenVertex and distance>0) I know that this point could be elevation point. I do loop for each pair of vertex.
However, I want Elevations point that feature line already has.
@joantopo wrote:
ok.
for (int i = 0; i <= oFtrLn.ElevationPointsCount -1; i++) { ...... }What´s the differece between Point and PI?
About this:
My first reply shows how to get the existing elevation points. What Christopher was saying is that if you are wanting to set a new elevation point, and perhaps you have the user select a point on screen, make sure the selected point lies on the featureline.
ahhhh, ok!
I thought that you had copied my code snippet. XD
I see the difference now. Thank you!
