I am trying to add an additional component to the pipe out flow section in the manhole table (see attached) i have created an additional component in the pipe parts list, which is displayed in the pipe properties. but i can not work out how to get it to show in the manhole table for connected pipes
Solved by maximilian.kroner. Go to Solution.
HI Max,
i tried your suggestion of pasting the part type into the structure table but it did not work
Hi James,
okay... can you upload you drawing so that I can have a look at it? (you can also upload it to the salesforce case if you do not want to share it with all forum users)
You should get a mail from me. Just reply to that mail.
Hi @d.gwilliam,
as to my knowledge the in properties of the in/out flow pipes in the manhole schedule are hard coded. So at the moment you can only access your custom properties in the pipe table.
