I have attempted to adjust some double click action items in the CUI feature, however it seems that a yellow exclamation point appears next to my new double click action item, prohibiting them from working. I assumed there were some overrides, so I reset my Civil 3D to factory settings.
I did notice a number of double click items on my CUI menu after the factory reset, but they no longer appeared after I customized and saved my workspace. Is there a compatibility issue with double click actions and workspaces?
I am not able to run "restore" or "reset" C3D.CUIX either before or after the factory reset.
Solved by C3D_TomR. Go to Solution.
The exclamation mark is notifying you that another double click command is overriding this one. I suspect that the map.cuix is overriding the double click command that you have assigned.
In Civil 3D select the map.cuix and browse to and expand ACAD > Double Click Actions > Lwpolyline. Notice that the Object Name assigned here is also LWPOLYLINE. This double click command is overriding the one you created in the Civil.cuix Double Click Actions. If that's the case, I recommend that you edit or remove the double click command in the map.cuix listing.
Tom Richardson
CAD Manager
Crossing the line with Civil 3D
Twitter | LinkedIn
If you find an answer to your question, please mark Accept as Solution so others can find it...
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
