I am creating new corridor with some of baselines and / or regions from existing corridor. I have implemented basic functionalities.
But while doing it, I could not copy following properties from original corridor to new corridor,
1) Parameters viz. Target and Overrides.
2) codes (Link, Point, Shape)
3) Feature lines with styles
4) Surfaces and its specified codes
5) Boundaries
Please guide me to set all (/any) of these properties from original corridor to new corridor.
Thanking you for all your help,
Mahesh
Solved by augusto.goncalves. Go to Solution.
Hi Augusto,
As you suggested, I created the new corridor by using clone method.
But when I undo all, the corridor surface from original corridor gets unchecked (Corridor->Properties->Surfaces).
As per standard behavior, all properties from original corridor must be intact when I undo all processes that I have done in the last transaction.
Please suggest me the way so that I can restrict the change in original corridor surfaces.
Thanking you,
Rahul.
