I try to make a copy of an assembly using .Clone. I do get a copy, but it seems like the subassemblies are not copied, but are still under the copied assembly. Is there a way to copy a assembly with subassemlies? Or do I have to add an Assembly to the collection and then copy the subassemblies?
using (Transaction tsa = CadApp.Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction()) { ObjectId myassemblyId2 = doc.AssemblyCollection[0]; Assembly myassembly2 = tsa.GetObject(myassemblyId2, OpenMode.ForWrite) as Assembly; ed.WriteMessage("Assembly name: {0}\n", myassembly2.Name); // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = tsa.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = tsa.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a copy of the assembly Assembly dd = myassembly2.Clone() as Assembly; dd.Name = "copy of assembly"; // Create a matrix and move the assembly using a vector from (0,0,0) to (-50,0,0) Point3d acPt3d = new Point3d(0, 0, 0); Vector3d acVec3d = acPt3d.GetVectorTo(new Point3d(-50, 0, 0)); dd.TransformBy(Matrix3d.Displacement(acVec3d)); // Add the cloned assembly acBlkTblRec.AppendEntity(dd); tsa.AddNewlyCreatedDBObject(dd, true); // Save the new object to the database tsa.Commit();
Quite an old post, but I was facing the same issue. I solved it by manually copy the subassemblies to the cloned assembly:
foreach (var group in originalAssembly.Groups)
int index = 0;
Subassembly previous = null;
foreach (ObjectId id in group.GetSubassemblyIds())
Subassembly subassembly = t.GetObject(id, OpenMode.ForRead) as Subassembly;
if (index == 0)
var newGroup = assemblyClone.CopySubassembly(subassembly.ObjectId);
var newSub = newGroup.GetSubassemblyIds()[0].GetObject(OpenMode.ForRead) as Subassembly;
previous = newSub;
else
ObjectId newSubId = assemblyClone.CopySubassembly(subassembly.ObjectId, previous.Points[subassembly.PointIndexHookTo]);
var newSub = newSubId.GetObject(OpenMode.ForRead) as Subassembly;
previous = newSub;
index++;
