I am trying to create a point label style to not show the first 2 digits of the elevation to save space in the drawing. Any help would be appreciated.
Solved by Jeff_M. Go to Solution.
I see how that expression would work for spot elevations but I can not get it to work on cogo point elevations.
<[Point Elevation(Uft|P2|RN|AP|Sn|OF)]> The format I am not seeing?
Thank you I just didn't realize I had to add a new expression in order to get that done.
So I am kind of dumb when it comes to programming. I really need to learn to trunc my point elevations in my point label style, but can not get your fancy expression to work and I don't understand the gentleman that said he just had to add a second expression. I also try to download the drawing from the link and it says 404 error not found. If you could please put this in a simpler format or help me get this figured out I would appreciate it very much. Thanks.
OK I figured out how to make new expression, but when I make it in the point label styles and create your expression, instead of removing the first 2 digits it changes the last 4 digits to 0. ie. 4899.95 becomes 4800.00. not sure why.
