Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Alignment StationOffset method
2 REPLIES 2
tcorey
481 Views, 2 Replies
I am attempting to populate point description with station/offset from an alignment.
Alignments have a method called StationOffset(4), where you give it X, Y and it returns Station and Offset. Given alignment variable called algn, the following shoud work, no?
(vlax-invoke-method algn 'StationOffset ptx pty sta off)
ptx and pty are real numbers. Sta and off are the variables into which I want to place station and offset. If I don't create those variables ahead of time, I get:
; error: ActiveX Server returned an error: Parameter not optional
If I do create the sta and off variable ahead of time, I don't get the error, but the variables are not re-populated.
Any ideas?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
2 REPLIES 2
Jeff_M
in reply to: tcorey
@tcorey wrote:
Any ideas?
Yes, use the Sincpac-C3D tools for this, it's much simpler and you can link the points to an alignment so they will update as needed. Smiley Very Happy
However, to answer your question, when you pass a variable to a method which will fill said variable, precede it with a quote:
(vlax-invoke-method algn 'StationOffset ptx pty 'sta 'off)
tcorey
in reply to: Jeff_M
That's the first thing I told him, that SincPac can do this, but his firm is under the thumb of a large international firm and they won't allow purchase of third party software, even if paying for a custom solution costs more. It's messed up, but that's the corporate world for you.
Thanks for helpng, Jeff.
Tim Corey
Redding, CA
Rail Community
