Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Adding text to a line or curve label TAG
3 REPLIES 3
zootango
511 Views, 3 Replies
I have a line label TAG, lets say it is L1, I can right click on it and select "edit label text" and I can add text to the end of it.
But how do I get the text that I add to the TAG label go underneath the TAG label L1?
Example I want this particular TAG label to be L1, but I want to add the text EIP TO EIP underneath the L1 text.
Is there a symbol our something you use that tells it to put the additional text underneath the original TAG Label of L1?
3 REPLIES 3
Jeff_M
in reply to: zootango
When editing the text, just place the cursor at the end of the tag line, hit enter, add the new text.
zootango
in reply to: Jeff_M
Thanks Jeff, simple enough, I should have figured that myself.
Jeff, how do you get the added text to center under a "DRAGGED TAG LABEL",  when I add text to a dragged tag label, it puts the TAG and the added text to Left Justified.
Jeff_M
Unfortunately, the only way to get the centered text is to set the dragged state to As Composed. But, that typically changes other aspects of the drag state that you don't want. When the text is stacked, it will be either left or right justified, depending on where you drag the label.
Rail Community
