I have a line label TAG, lets say it is L1, I can right click on it and select "edit label text" and I can add text to the end of it.
But how do I get the text that I add to the TAG label go underneath the TAG label L1?
Example I want this particular TAG label to be L1, but I want to add the text EIP TO EIP underneath the L1 text.
Is there a symbol our something you use that tells it to put the additional text underneath the original TAG Label of L1?
Solved by Jeff_M. Go to Solution.
Thanks Jeff, simple enough, I should have figured that myself.
Jeff, how do you get the added text to center under a "DRAGGED TAG LABEL", when I add text to a dragged tag label, it puts the TAG and the added text to Left Justified.
