Version 2024 - Is there a way to highlight a layer in a defined color, to see if something is on the wrong layer?
Logos_Atum
Logos_Atum
I have been dimensioning a plant for an architect and while at it, I noticed I switched tot he wrong layer at some point. I had to manually select all the dimensions and change their layer to the right layer. Given I could have colored all contents of the layer they belong to as a whole, in a color I can define, I could simply have selected them based on a color mismatch. Is this possible? Is there an override for the color of grouped objects like dimensioning?
Kind regards
Daniel
Dogs aren´t flammable.
David_W_Koch
You could have used QSELECT to select all of a given type of Dimension on a given layer, then changed the layer in the Properties palette.  If you have multiple types of dimensions, you would have to repeat that for each type (or get comfortable with the Append to current selection set option - I usually mess that up at some point and have to start over).
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Logos_Atum
David,
thanks for the answer. That sounds more than feasible. I use a defined stlye for each type of dimention, therefore I can easily fetch them all with the routine you described. That´d spare me at least the random lines I must have selected instead of the dimensionings that I wanted to select. The ones that pop when you isolate the layers to check if it´s all ordered in the end.
Kind regards
Daniel
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
