Variables
Variables
Message 1 of 11
Variables
Hi all,
Is there a way in lisp to set dimvars for precision and dimanno? (trying to
automate old dims to annotative dims in lisp).
Is there a variable to set drawing precision?
Melvin Donaldson
Tech Support
Kephart
Community-Planning-Architecture
Replies (10)
Message 2 of 11
Drawing precision variables:
AUPREC - angular units precision
LUPREC - linerar units precision
Dimension precision variables (you may need to set these by dimension style??? - I have not played with dimension variables directly in years):
DIMADEC - angular dimension units precision, set to -1 to use DIMDEC setting
DIMALTD - alternate measurement precision
DIMALTTD - alternate units tolerance values precision
DIMDEC - primary units precision
DIMTDEC - primary units tolerance precision
I can not help with the annotative dimension question.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
Message 3 of 11
Thanks David.
wrote in message news:[email protected]...
David Koch
Message 4 of 11
You can make a dim style annotative either in the Dimstyle dialog (Fit tab),
or with the -Dimstyle command.
To make existing dims annotative, the Chprop command will do it.
Ken Krupa
Autodesk Authorized Developer
Krupa CADD Solutions
www.krupacadd.com
KCS Productivity Pack for AEC
KCS Productivity Pack for AutoCAD
"Melvin Donaldson" wrote in message
Hi all,
Melvin Donaldson
Tech Support
Kephart
Message 5 of 11
Ken,
Thanks for your help.
How do I change cannoscale in lisp. I saw you post the answer before.
Something about adding a slash after the inch sign but I couldn't get that
to work for me.
Will you re-post that answer and I'll try it again.
Melvin
"Ken Krupa" wrote in message
Ken Krupa
www.krupacadd.com
Hi all,
Melvin Donaldson
Tech Support
Kephart
Message 6 of 11
"Escape" the quote with a backslash:
(setvar cannoscale "1/4\" = 1'-0")
Or do this:
Here is a function for converting a
scale (real) to a string:
(defun kcs_scaletos (scale)
(if (> (getvar "lunits") 3)
(if (= (fix (/ scale 10.0))(/ scale 10.0))
(if (= (fix (/ scale 12.0))(/ scale 12.0))
; Engineering [ex: 480 => 1" = 30']
(strcat "1\" = " (rtos (/ scale 12.0) 2 0) "'")
; Bogus (display as ratio)
(strcat "1 = " (rtos scale 2 0))
; Architectural [ex: 1/16" = 1'-0"]
(strcat (rtos (/ 12.0 scale)) " = " (rtos 12.0))
; Decimal [ex: 1=50]
(if (= (getvar "measurement") 1) ; metric
(strcat "1:" (rtos scale 2 0))
Then you can do something like
(setvar "cannoscale" (kcs_scaletos 48))
Ken Krupa
www.krupacadd.com
Ken,
to work for me.
Melvin
Message 7 of 11
Oops - that should have been
(setvar "cannoscale" "1/4\" = 1'-0")
of course.
Message 8 of 11
Thanks Ken.
of course.
Message 9 of 11
Ken,
When I do this at the command line, Command: (setvar "cannoscale" "1/4\" =
1'-0"), I get this message.
error: AutoCAD variable setting rejected: "cannoscale" "1/4\" = 1'-0"
Am I missing something?
of course.
Message 10 of 11
Ah, yes. I was missing something - the inch mark after the 1'-0" needs to be
escaped also. This works:
(setvar "cannoscale" "1/4\" = 1'-0\"")
Ken,
of course.
Message 11 of 11
Ken,
of course.
