Unable to display the Ribbon, No Tools item to select and entering RIBBON does n
I am trying to display the ribbon menu.   Help says: Display the Ribbon
Click Tools menu PalettesRibbon or enter RIBBON at the Command prompt.
Note: The ribbon is displayed with the ribbon tabs assigned to the current workspace.
There is no 'Tools' menu item anywhere!, Entering RIBBON at the command prompt followed by Enter does nothing??
What am I missing here?
David_W_Koch
What version of AutoCAD Architecture are you running?
AutoCAD Architecture does not include pull-down menus in the out-of-the-box ACA.cuix file, so not having a Tools menu is not a surprise.  You say typing RIBBON at the command line and pressing the ENTER key does nothing.  There is no message saying something like "Unknown Command" at the command line?  If not, then nothing is exactly what I would expect from the RIBBON command when the ribbon is already displayed.
Does the top of your AutoCAD Window look anything like the image below?  In particular, do you see Home, Insert, Annotate, etc. just below the Quick Access Toolbar?2018-05-05_ACA2017_RibbonMininizedToTabs.png
If so, then you have minimized the Ribbon to tabs, so only the tabs display.  If you left click on a tab, the full ribbon tab will display, and you can choose a tool.  To restore the ribbon to full display, find the button to the right of the last ribbon tab name, and select it.  (The red arrow in the image is pointing to this button in the image above.)
There are other minimize states:  panel tabs and panel buttons.  Panel tabs shows the names of the tabs of the currently selected ribbon tab below the ribbon tab names; hover over a panel name to see the full panel.  Panel buttons shows a the panel names with the icon of the first tool on the panel in a "button".  Hover over the button to see the full panel.  If you are in one of these other minimize states, you can restore the full ribbon using the same button at the far right of the tab names noted above.  If you are set to cycle between all ribbon states, you will have to click more than once to get to the full ribbon.
If that is not what you are seeing, you may need to try a repair install or a reinstall.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
What version of AutoCAD Architecture are you running?  Version 2019
You say typing RIBBON at the command line and pressing the ENTER key does nothing.  There is no message saying something like "Unknown Command" at the command line?  It does not display any messages.
Does the top of your AutoCAD Window look anything like the image below?  In particular, do you see Home, Insert, Annotate, etc. just below the Quick Access Toolbar?  Yes it does look like this example.2018-05-05_ACA2017_RibbonMininizedToTabs.png
There are other minimize states:  panel tabs and panel buttons.  Panel tabs shows the names of the tabs of the currently selected ribbon tab below the ribbon tab names hover over a panel name to see the full panel . Panel buttons shows a the panel names with the icon of the first tool on the panel in a "button".  Hover over the button to see the full panel.  If you are in one of these other minimize states, you can restore the full ribbon using the same button at the far right of the tab names noted above.  If you are set to cycle between all ribbon states, you will have to click more than once to get to the full ribbon.
Wonderful explanation and solution.
Thank you so very much.  It would be nice to have that little item in the docs, maybe under 'Menu Pallets'.  Help systems cannot be created by experienced users as they always miss little details like this.
I might suggest that the reply page in this forum should include the answer we are replying to that one could scroll to.  I had to copy your answer into my reply so I could answer appropriately.
 Thanks Again!!
David_W_Koch
@Anonymous
If you press the QUOTE button in the tool bar above the edit window when replying, it will copy the contents of the post to which you are replying, like this:
 Thanks Again!!
David Koch
Blog | LinkedIn
