Setting AutomaticUpdate for ScheduleTableStyle
Hello. I can set AutomaticUpdate for ScheduleTableStyle (table.AutomaticUpdate = true).
How can i set AutomaticUpdate for style of ScheduleTable (ScheduleTableStyle) ?
David_W_Koch
So far as I know, Automatic Update is a property of the Schedule Table, not of its Style.  If you create a Schedule Table from a Tool palette tool, you should be able to specify that the Schedule Table automatically update in the tool's properties.  If you are creating some sort of customization that creates a Schedule Table Style and then places an instance, I believe you will have to set the Automatic Update on the instance, not in the style.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
