Programmatically add body modifier to WALL object
Hi
I'm writing a program (in Matlab) that creates a text file with AutoCAD commands. I can execute these commands by copying them to AutoCAD's command line.
I have a need for adding a body modifier to a wall object with this approach: adding the body modifier only from the command line without any POP-op windows. This gives me trouble!! I can't find a way to avoid the POP-op window:-(
I hope that there is a way around this? Perhaps a LISP script (VBA/VLA) that can be loaded into AutoCAD and then called from the command line?
Any help/input would be greatly appreciated.
Best Regards
Jesper, Denmark
I need to programmatically add a body modifer to a wall element.
brian_adams
hyphen "-" in macro suppresses the opening of dialog boxes
Hi Brian
Thanks for your respond.
I now that for some functions AutoCad has a variant with a "-" that suppresses dialog boxes. One example is the "ADDWALL" function, here I can use the "-ADDWALL" function to draw a line directly from the command line.
However, for the  "WALLBODYMODIFIER" a do not think that AutoCad has a the "-" variant 😞
I have found the following link:
https://adndevblog.typepad.com/aec/2013/02/adding-a-body-modifier-to-a-wall.html
As I understand the approach shown in the link above require creating a .NET script for AutoCad. Any idea if the approach would be helpfull for my need?
/Jesper
brian_adams
it happened because ACA want to choose one option via dialog box . I haven't ideas...you need someone how knows ACA as programist,sorry can't help you-lack of knowlage
