Overkill, Audit, Purge all in one toolbar button
jduframe
jduframe
Trying to create a Toolbar Button that would Overkill, Audit, & Purge entire Drawing with out all the extra steps,
starting with overkill I am not understanding, does it always need you to select objects?
was trying this: ^C^C_-overkill;all;
I think Purge would select entire drawing by doing a dash before command?  ^C^C_-Purge;a;*;n;
 Audit would be :    audit;y;
so would the Macro line in the button be as this:  ^C^C_-overkill;all;^C^C_-Purge;a;*;n;audit;y;
jduframe
think I got it, it appears to function and work
had to add couple more ; after the overkill
^C^C_-overkill;all;;;^C^C_-Purge;a;*;n;audit;y;
jduframe
now I am wondering if the order of the commands is wrong? should audit happen before purging?
pendean
Community Legend
Community Legend
-PURGE that calls REGAPPS as well as "all", then AUDIT, then -PURGE again that calls "all", then -OVERKILL then -PURGE "all" again at the end, because as HELP says...
