Lisp Routines in Acaddoc.lsp Not Loading in ACA 2025
jeffrey_Moskovciak
jeffrey_Moskovciak
Hi, my team has begun testing ACA 2025, and one thing that I noticed is not all of the lisp routines saved in our Acaddoc.lsp file are loading. If I save the routines separately and load them individually, they work. Is there a setting in ACA 2025 that I'm missing?
jeffrey_Moskovciak
And to add to the weirdness of the situation, the routines DO load and work in a new drawing, but not in an existing file.
pendean
Community Legend
Community Legend
Unless your last version your LISP worked well was like ADT2004, it's most likely something else going on like a missed location change (or bad spelling) of that LISP name in your search paths and trusted folder lists in OPTIONS' FILES tab in your ACA2025.
Feel free to share one of those LISP here along with your acaddoc.lsp file, and provide details on how you are set up.
As for new vs old drawing, are those failing LISP routine more for old block definitions vs new blocks?
You'll also want to share new vs old DWG samples too.
Type a product name
