Layout is not at 0,0
Message 1 of 23
I was wondering if anyone has any idea's why my layout is not at 0,0? I
drew a line from 0,0 and it starts way over to the left of my printable
area? I have written a post before about xrefing my titleblock and it
doesn't insert at 0,0. Any idea's would be great!
Replies (22)
Message 21 of 23
pendean
Community Legend
Community Legend
@mhy3sx wrote:
Hi, I have the same problem. I read all the post but the problem not solved. Is any  command or lisp code can fix this problem? Thanks
1) Open PAGESETUP command in that layout, select a different printer/plotter. Exit. Go back in, then go back to the printer/plotter you want, see if that resets it for you.
OR
2) Open PAGESETUP command in that layout, select a different sheet size. Exit. Go back in, select your desired sheet size.
OR the quickest fix:
3) Create a new layout. Copy/paste content from bad to good, then delete the bad layout.
Message 22 of 23
pcelentanoK82CP
Check that you do not have any stray lines or text floating outside the edges of the sheet.
Message 23 of 23
mhy3sx
I try everything Plot area window, or Extends or layout, change the size of the paper. After all this the drawing fit toy paper but the 0,0 is not correct  (for little is wrong).  Is any lisp or something to reset the layout. The only solutions for me is to copy and paste all in new layout. But if you have a big job with a lot of text and photos and viewports, this is a disaster. I need a fast solution. Can anyone help?  Thanks
