Keep text 'Left Reading' in Blocks
Is it possible when creating a block (or dynamic block) to keep the associated text reading correctly. For example if I create a symbol for a Bathtub and have one single line text associated for it to stay left reading when rotated or mirrored without having to build in a 'flip' function to get the text to read right?
Thanks!
pendean
Community Legend
Community Legend
Use ATTRIBUTEs and not TEXT objects in your blocks to avoid the issue.
BTW, the dedicated Dynamic Blocks forum is over here if you'd like more folks looking at your issue, but when you repost there do yourself a big favor and share the actual block in a DWG file and not a useless image https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
