Having a bit of trouble with my wall/door display.
We want to have a single wall that can be displayed in 3 ways knee wall (Below Cut Plane), full height (Floor to Ceiling), and a header/bulkhead (Above Cut Plane). We have it setup properly so the above and below cutline versions of a wall works as we desire. That being said when we put in a door we would like it to just show an open portion of the wall (See Image #2 below) and not show the same above cut line display style as if it was a header/bulkhead (See Image #1)
Is there some option I need to check or uncheck so the door cuts appear like it does in Image 2 without the dashed lines above the cut plane? I know I can turn off the ABOVE CUT PLANE in the display properties but this would eliminate the possibility to set the wall as a bulkhead. Of course we could just make this type of wall a separate style but if possible I would like to limit the # of standard walls if that is possible.
Image #1 (Not what we want)
Image #1
Image #2 (What we want)
Image #2
