would it possible to create slab style with programming code(Visual Lisp, .vb of other language )? ... I mean to say ... creating custom command in ACA which create custom slab style(custom compoenent ) in respective dwg file without from toolpalette or style browsing.
Please let me know , if it is possible
Chirag Rana
I made library in terms of tool palette which I use normally in current practice. However, I have to use custom slab, custom wall, etc. they are vary from project to project. Sometime it is time consuming to create a style from scratch with appropriate properties. So I am wondering, if i can do with a command line of lisp code or any other language. I would like to avoid clicking the more button in GUI panel.
Chirag
Thanks for reply and suggestion of my question.
Is there any training source available for .net in autodesk application(AutoCAD architecture)? So the beginner can start learning and go further in this field.
Chirag Rana
