AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Hide palettes
2 REPLIES 2
jesusSYG32
1532 Views, 2 Replies
Hide palettes
Hello all,
We're working on AutoCAD Architecture 2023. When we open it we always have this palette open. We don't want to have this palette. What can we do so when we open AutoCAD this palette doesn't show automatically?
Thank
Labels (2)
2 REPLIES 2
pendean
in reply to: jesusSYG32
Close it not an option? Or is your workspace and profile loaded from an external startup someone created for you all?
Or close it then actively save that workspace using WSSAVE command. Repeat for every workspace and profile you might use. unless, as I noted above, someone is forcing you all with a reset at startup.
If you had something else in mind then please share your thoughts.
HTH
jesusSYG32
Close is an option but I was tired of closing it each time I open AutoCAD. WSSAVE solved it.
Thanks!!
Forma Design Contest
