Display changes in edited Blocks with attributes?
maurot.ferrarese
maurot.ferrarese
Hi all,
I have made a block with a text attribute inside and it works perfectly for what I need. The problem I find is that when I have to make a change to that block, I can only see the changes in the new inserted blocks. All the already placed blocks remain the same.
So for example, when I change the text style of a block text attribute, I can only see the changes in the new inserted blocks, but all the block before the text style change, have the same old text style.
Is there that the change affect all the other blocks at the same time?
Gepaha
Have you tried using _BATTMAN?
David_W_Koch
@maurot.ferrarese
As @Gepaha mentioned, you can use the Sync option of the BATTMAN command to update existing instances of attributed blocks.  Or you can use the ATTSYNC command to do the same thing at the command line.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
