CUI changes not taking effect
I used the CUI editor to make a change to the mouse button section of the ADT.CUI file, but the changes aren't taking effect. I shifted everything from buttons 5-10 into buttons 6-11 and put a new command into button 5. Afterwards though, buttons 5-10 still do the same commands as the original configuration. How do I get the revisions to become active? I notice I have two copies of ADT.CUI in different folders with different dates (...\enu\Support\ and ...\userdatacache\Support\). One is an old date, and the other is the day I made the revision. Do I need to erase the old one?
Would a better solution be to make these button changes in a partial CUI rather than modifying ADT.CUI? What would happen if a partial CUI has a different mouse button arrangement than the main cui?
How many ADT.CUI files do you have in CUI?
_________________________
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
Notice: New LISP tool for Landscape
Design and for ATTEXT users.
Measure and Divide with attributes!!
wrote in message news:5901493@discussion.autodesk.com...
I get the following Microsoft.NET Framework error message when I try to customize my CUI:
Unhandled exception has occured in a component in your appliucation. If you click Continue, the application will ignore this error and attempt to continue.
Invalid URI: The format of the URI could not be determined.
Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UriFormatException: Invalid URI: The format of the URI could not be determined.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at System.Uri..ctor(String uriString)
at Autodesk.AutoCAD.Windows.RibbonData.LoadImageW(CStringT > >* sImage, HINSTANCE__* hResInst, Boolean bSmall)
at Autodesk.AutoCAD.Windows.RibbonData.Load(String sImage, String sModule, String sGroupName, Boolean bSmall)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ApplyMenuMacro(RibbonItem item, MenuMacro menuMacro, String sMenuGroup)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ResolveReferencesInObject(Object obj, Object parameter)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ResolveReferences(RibbonItem item, ReferenceResolver resolver, Object parameter)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ResolveReferences(RibbonPanelSource panelSource, ReferenceResolver resolver, Object parameter)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ResolveReferences(ReferenceResolver resolver, Object parameter)
at Autodesk.AutoCAD.Ribbon.RibbonContent.ResolveReferences(List`1 menuGroups, RibbonContentCollection partialRibbonContents)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.LoadRibbon(String sWorkspaceId)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.CuiEventManager_LoadRibbon(Object sender, CuiLoadEventArgs e)
at Autodesk.AutoCAD.Internal.Reactors.CuiEventManager.FireLoadRibbon(String sName, String sID)
at acmgdFireLoadRibbonEvent(Char* pszName, Char* pszID)
at acedReloadMenus()
at Autodesk.AutoCAD.Internal.Utils.ReloadMenus(String wsCurrentStr, Boolean bResetWorkspace)
at Autodesk.AutoCAD.Customization.MainForm.okButton_Click(Object sender, EventArgs e)
at Autodesk.AutoCAD.Customization.MainForm.applyButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.2.0.0
Win32 Version: 17.2.56.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcdbMgd.DLL
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.0 (vista_rtm_wcp.061020-1904)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
acmgd
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/acmgd.DLL
AecSpaceOffsetRulesManager
Assembly Version: 5.7.68.0
Win32 Version: 5, 7, 68, 0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecSpaceOffsetRulesManager.DLL
AdWindows
Assembly Version: 1.0.0.0
Win32 Version: 1.0.56.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AdWindows.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
AecSpaceOffsetStandardBasic
Win32 Version: 5.7.68.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecSpaceOffsetStandardBasic.DLL
AecBaseMgd
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecBaseMgd.DLL
AecSpaceOffsetStandardBasic.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AecSpaceOffsetStandardBasic.resources.DLL
AecArchMgd
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecArchMgd.DLL
AecSpaceOffsetStandardBOMA
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/Space%20Calculation%20Standards/AecSpaceOffsetStandardBOMA.dll
AecSpaceOffsetStandardBOMA.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AecSpaceOffsetStandardBOMA.resources.DLL
AecSpaceOffsetStandardDIN
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/Space%20Calculation%20Standards/AecSpaceOffsetStandardDIN.dll
AecSpaceOffsetStandardDIN.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AecSpaceOffsetStandardDIN.resources.DLL
AecSpaceOffsetStandardSIS
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/Space%20Calculation%20Standards/AecSpaceOffsetStandardSIS.dll
AecSpaceOffsetStandardSIS.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AecSpaceOffsetStandardSIS.resources.DLL
AecDtlDb
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecDtlDb.DLL
AecDtlDbUI
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecDtlDbUI.DLL
AecDtlDbLib
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecDtlDbLib.DLL
AdWindowsWrapper
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AdWindowsWrapper.DLL
AcMgdReverse
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcMgdReverse.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcWindows.DLL
AcRibbon
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcRibbon.DLL
AcRibbon.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcRibbon.resources.DLL
AdWindows.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AdWindows.resources.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/acmgdinternal.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcWindows.resources.DLL
AcMrUi
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcMrUi.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcMrUi.resources.DLL
AcMr
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcMr.DLL
System.Runtime.Serialization
Win32 Version: 3.0.4506.30 (WAPRTM.004506-0030)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcPrevInput
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcPrevInput.DLL
AcXrefUtil
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcXrefUtil.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AdInfoCenter.DLL
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AdInfoCenter.resources.DLL
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
1sqhhy9v
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Autodesk.Interop.WSCommCntr1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/Autodesk.Interop.WSCommCntr1.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcLayer.resources.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcCustomize.DLL
AcCui
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcCui.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcCustomize.resources.DLL
AecUiToolTipContent
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AecUiToolTipContent.DLL
AecUiToolTipContent.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AecUiToolTipContent.resources.DLL
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcCommandToolTips.resources.DLL
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Autodesk.AutoCAD.Interop
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop/17.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.dll
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202009/en-US/AcDialogToolTips.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I have two ADT.CUI files on the single computer in the folders mentioned in the original post. Regardless of which one I edited, it didn't have any affect. But I eventually found the problem. The solution was that I was modifying the mouse button area, but I wasn't technically using a mouse. I was using a tablet and hadn't noticed there was a similar "tablet buttons" area in Legacy devices. When I moved my modifications from "mouse buttons" to "tablet buttons" they all worked.
