Component Plan Hatch and Display representation issue
I am trying to set some typical wall styles at my office in a way that they show more detail when in standard display representation, and less detail when in low detail representation. The more easy and logical way I found to edit the walls, is right click on them, selecting the components and changing the hatchs in the properties. So I have 1 concrete wall and 1 drywall, each one with the material assigned to it and controling the display of the walls. In standard display it works fine, the issue is when I choose low detail in the display configuration. When I select the component of the drywall and change the hatching, it also change the hatching in the concrete wall, as you can see in the pic attached. I went through the display of each material to check if the problem was in the display setting of the material but I couldn´t find anything there and I can´t think of what could be the problem. What am I missing?
