Attributes to designated layers
Message 1 of 1
When I use the Desin Center with blocks with attributes the Attribute gets created onto the layer set by the layer key.
This does not work right for me. e.g. I have a tree symbol with Botnaical Name, Common Name and Plant Size. I want the Block to be inserted on thr tree layer so all trees can be frozen easily. But I need the Attribute Name on a different layer and the size on a different layer. I need to be able to view only the Size of the Plant Attribut occasionally. But in the final printing this information should be frozen. What can I do or what am I doing wrong?
THANKS!!!
Merlin
Replies (0)
