We followed the recommendations given in: http://discussion.autodesk.com/thread.jspa?messageID=5552957 to install Architecture 2008 on 64-bit Windows XP. This installed fine and Architecture 2008 works OK. However, we are unable to install the Object Enabler.
We have tried using both autocad_architecture_2008_oe.exe and autocad_architecture_2008_oe_x64.exe without success. The first installer will not run, because it grumbles about the o/s. After extracting the MSI file, the MSI installs OK, but the app (Architecture 2008) does not recognise that the OE has been installed. (Probably due to incorrect default paths/registry entries.)
The second installer (x64) will not run, as it grumbles that it cannot find an associated application installed.
Can anyone help, please?
