Hi
When i create a new representation by object in the display manager, for windows or any other objects, i need to close AA and open again to see the new representation in the object and in the Sets too.
It works fine then, but is not a correct workflow.
Does anyone have the same problem or have any solution to this?
Please look the attach.
Im using AA 2016.
Cheers.
Solved by Laks-Autodesk. Go to Solution.
Hi Richard,
I've logged this issue with our development team so they're aware of this issue.
Unfortunately there seems to be no better workaround than what you've already discovered.
Laks
Hi @Richard.Vivanco,
I've linked your escalated case to the open development issue that Laks mentioned he logged.
Hopefully we'll see a fix for this in the near future. Thank you for your post!
